04 Fleetwood Yukon slide out problems!!!
Ahayes99
I just became a proud owner of an 04 Fleetwood Wilderness Yukon 830 and I can't figure out this slide out issue. Previous owner said it just recently stopped working. I've tested the motor and it worked with direct power, pulled the switch apart and it was busted. I replaced the switch and checked all fuses and breakers and still won't move with the switch. Any help would be appreciated since this is my first camper.
The switch usually sends a signal to a relay. The relay could be bad.
Also on my full wall slide, I have a time delay relay.
I have to hold the switch for 2-3 seconds before the slide starts moving.
I've had my wife hold the switch while I inspect wires all over the place. Where would the relay be located? I feel like I've traced everything and never saw one.
Someone has to look at your coach. I m not familiar with it. Can you call the manufacturer for some idea where to look?
Unfortunately from what I have learned is Fleetwood went bankrupt back in 09 and now all they produce is motorhomes.
