110 plug is warm!!!
j105
help my 110 plugin is warm and nothing is plugged in to it it tripped the breaker when I hit the reset or test button please someone help me before my home burns down I really don't know what to do I want to solve it but if it's a water problem or how do I tell????
Are you talking about a 110 plug from your RV To your house? If so, I suspect it is the battery charger drawing the current…as they can pull quite a bit depending on what you set them to.
Not sure what you mean about a water problem….
If this is at a standard, household-style of 120 volt AC cord, this is not good but also not unexpected. You are likely drawing a lot of amps through it and you now have two choices - upgrade the cord to a heavier gauge of wire or don't power so many big consumers of electricity inside your RV.
Rick
If you reset that tripped breaker, then turn it back off and call an electrician to check things out.
Roger
