Problem 12v power
DLB
I only have 12v power when hooked to shore power. The battery is fully charged. Any suggestions?
Did you check the CG power pedestal circuit breaker? On? does the CG have power? Is the Transfer Switch engaging? You should here a clearly audible thud of the transfer switch power solenoid when you plug into CG power after a few seconds of self checking by the transfer switch.
Please explain what CG power pedestal breaker is. When I plug in to shore power the fan kicks on for a sec. Red light is on all the breakers are on and fuses are good. I checked the inline fuse it good. I have power going through the what seems to be a manual breaker. I am lost.
