1992 Independent on Dodge B350 w/sloppy steering
RoadLessGraveled
Roadtrek
Dodge B350
Just bought this old girl, with 112K miles on it. Engine and transmission are strong, everything works...except the steering.
Terrible oversteer, with slack in the steering wheel between 10 and 2. Most of the usual suspects have been replaced, like idler arms, center link, ball joints, tie rod ends and drag link were replaced 12K miles ago.
When turning the steering wheel through the range of it's "slack", the steering shaft turns within the steering box but there is no rotating of the pitman arm, and when the arm does move, there is some side to side movement within the bore of the steering box.
I intend to replace the steering box and coupler, and possibly add a steering stabilizer if needed.
I have heard that the alignment for the Roadtrek on this Dodge is different than for the B350 without the RV package. Mostly differences in camber. Has anyone heard of this?
I'm really looking forward to traveling in this. My hope is that I can make the steering solid enough so my wife can drive. She used to drive a 14 passenger bus, but the oversteer is scary. It wanders to the right, and when you correct for that it oversteers to the left, and then you correct for that...and it looks like I'm driving drunk! And that's not a good look!
Glad to be here,
Dan in Wisconsin
Not a mechanic, but I'm pretty sure I wouldn't want to drive it until whatever is going on in the steering wheel-steering box and they get looked at closely, adjusted, or replaced. A 1992 is now 32 years old, and although low mileage, who know what is going on inside. Don't bandaid a steering gear problem with swaybars.
FWIW, I have found that tire pressure & shocks can alter a van's handling significantly as well, but I'd make sure someone smarter than me looked at that steering box (worn gear? shaft?) before trusting it with anyone's life. Problems with steering are unforgiving in many situations.
I was focusing on the front but I am sure there must be one available. Those had factory sway bars, is the rear missing? Have you replaced the sway bar bushings? Links?
My factory service manual doesn't show a rear sway bar, but it's not a Roadtrek manual...did Roadtrek install one on these? That would make sense to do that with the weight in the back as it is.
Yeah...I won't drive it until it's tight. There is too much slack in the steering box, and while I could adjust it...the pitman arm moves laterally in the bore of the steering box as it begins to rotate...not much, but it shouldn't move that way at all, IMO. Rebuilt boxes aren't too spendy, but the quality is a gamble, so I'm going with a "Redhead" steering box, and a new coupler.
Even with a good steering box and coupler, a rear sway bar would help with the body roll that will naturally happen with that much weight over the rear.
Shocks are new, tires at 60psi front/80psi rear.
Anyone stating that a sway bar does not help oversteer has never driven with one and without one. Stating that a sway bar will help is not saying to ignore the steering box issue. But oversteer is present on these vans without a sway bar even with a perfect steering box. I installed many on older classics in my hot rod shop.
Its not a Roadtrek item, it would be a Dodge item. In another life I was the head of production for a sway bar manufacturer. I do not recall if they made them for that model but they made some monsters for class a motorhomes.
So far I have only found a rear one for a small gas tank model. But you can call Heliwig and ask them (not who I worked for) if they make one for that year with the large gas tank
I haven't replaced the bushings or links, they seem tight, though.
I would replace every part on that front end. Pull the steering box and get it rebuilt or buy a rebuilt one. If its beyond your capabilities find a good shop to do it. Bushings, etc, make a huge difference. Every component on that front end needs to be up to par
Replace the box!!!
Have the frame checked for cracks in that area, as in the past there was a recall, years I don't remember.
Sway bar is always a good thing.
Helper air springs are good, leafs checked and maybe resprung?
And when loaded as you plan to have her loaded. Take her down and make sure you have the weight front to back within the design limits. This very important measure can lead to oversteer or under steer. Furthermore the lower the center of weight the better!
Empty the balance can be off because they may have engineered for the loaded rig. C's and B's are more sensitive to weight distribution.
Rebuilt boxes get mixed reviews...they are too often not a whole lot better than the old one. I've got a "Redhead" steering box ordered.
The idler arms, lower ball joints and drag link have been replaced within the last 12K miles. There is no play in the sway bar links/bushings, center link or tie rods. I haven't checked the upper ball joints yet.
I agree...everything needs to be tight, but just given the weight distribution, a rear sway bar could really improve cornering from stock.
I just skimmed through this thread so I may missed this being mentioned already but did you try adjusting the steering box? With all of the movement in the steering wheel without the pitman moving you
Need to tighten that up. No matter what you have done with replacing other components it will drive like a bucket of bolts until you get a tight steering box. Easy to adjust, loosen the lock nut on the box and screw down the center screw until it bottoms and back it off slight and tighten jam nut. Check carefully for any tightness of binding by moving the wheel lock to lock. Then start and try again. Check wheel to pitman are again
If you want to try to adjust the steering box, it is more complicated than one might think at first. There are two adjustments, Input worm gear preload, and then the shaft lash.
Best, if you determine that the box is your problem, is to get a quality rebuild like Redhead. These are easy to replace and are not that expensive to purchase.
I am pretty sure that his box only has one adjustment and if he has that much play in the wheel without the pitman arm moving then the steering box is definitely a problem. I think it’s a lot easier to try adjusting it than it is to replace it. If adjusting it doesn’t get it tight enough then certainly a quality rebuilt replacement is the next step
I tend to forget that most people get there rebuilds from auto parts stores. When I had my shop I was fortunate to have a rebuilding shop nearby. They did alternators, steering boxes, old school generators and many other rebuilds.
Have you tried calling Helliwig?
I've got a request in to Helliwig for a rear bar that will fit the B350 with the 35 gallon tank. They don't show one on the website.
I'll start with the Redhead box and a new coupler and see how it handles.
I appreciate all the comments!
I just bought a 1990 Dodge versatile and took it for an inspection, and the very first thing they recommended is that I have them remove and replace the entire steering box assembly. Which cost me a pretty 1g. 😝
