Someone told me I could use a regular rear end from a Dodge 2500 or 3500 as long as same gear ratio and not (floating?). Any idea if this is true?It will be of only a few companies. I assume 1ton. A tag on one of the bolts should give you the gear ratio.
Good luck on part numbers, but should be able to find a rear-end for a dodge chassis.
