2002 Coach House Platinum 232 not charging coach battery
chstoyer
I have a 2002 Coach House 232 RV based on Ford E450. The truck no longer charges the coach battery. I found the battery isolator under the driver's door and tested it. There is 12V at the truck battery terminal but no voltage at the coach (secondary) battery terminal. When the truck is running, all 3 terminals show alternator voltage.
Presumably there is a fuse or circuit breaker between the battery cable connection on the switch in the area housing the converter but I cannot find it.
Does anyone know where this might be? Otherwise, I will eventually run a new wire and put a circuit breaker in.
Thanks for any help,
Charles
Welcome to RVforums. There are a lot of resources here. Has the charging system been working or did you purchase it this way? I am not qualified to respond directly about your specific rig as I am not familiar with it. I would see if you can trace the cables from the alternator output to the house battery. Good luck! Hoping you find a quick solution.
