2002 Tiffin Allegro plumbing
modrob
I’ve had to dig in and do some repairs that involve plumbing, and I’m trying to figure out what, how everything is routed. Manuals don’t show what I need, and I can usually figure things out, but some of it isn’t easy to see…
First, I have a white plastic tank in the bay just in front of the rear wheels, that is a water supply. And then I found another long, horizontal tank in the very rear, underneath the headboard. The access hole lets me see two blue lines with a cutoff valve in one. Both come from the tank side on passenger side, low and high. Then continue onto driver side, curves and then runs toward front. Also, on the driver side of tank there is a coiled plastic tube line (about size of a vacuum cleaner hose along with a small water-type hose running that way also.
I think that’s the only question I have at this point.
Thanks for any help.
The white one looks like a drain hose. Do you have a sink in a slide?
That was my first thought as well. Looks just like the one I have in the FWS for the kitchen sink.
