Question 2014 Flagstaff Microlite 23LB tub removal
PaulR
I have a Flagstaff Microlite, 2014, 23LB. I have a water leak in one of the WSO lines leading to the tub. When I pressurize my water line, water comes out underneath the tub. I have removed the access door to the and need to get the panel that door is in off in order to see where my problem is. I have removed the screw from the cover strip between the tub panel and the vanity, but it doesn’t really want to move much. I tried removing the cover strip between the tub and the panel. It doesn’t want to pop loose easily either. I don’t wanna break or damage anything if possible. I also felt along the strip on the bottom of the panel to see if there were any screws attaching it to the floor. I didn’t feel any.. I’m looking for suggestions as to how to move forward at this point.
Thanks, Paul.
If you can't find the method of securing the panel, cut a bigger hole, carefully and plan on making a larger hatch to cover it.
