2014 Sportscoach 385DS dash AC fuse location
adammarty
Does anyone know where the dash ac and heat fuses are?
The ac and heat worked fine and then just shut off.
I have checked the fuses in the compartment below the drivers seat all good.
1. Look for the blower motor connector plug under the dash, pass. side near the firewall. Unplug it and look for brown or melted plastic. If it's burn't you'll need a new connector 2. Check the solenoid under the driver side window in the front electrical bay. It may fail as it gets hot.
All the plug connections are good. I unplugged them all and checked them.
I didn't see the solenoid you spoke of.
I only have 2 fuse panels with fuses and small relays. Do you think it could be a relay? Not sure how to check? All fuses are good. Nothing is labeled ac or heat.
If it's shutting off intermittently it's likely the solenoid. Were it a fuse it wouldn't come back.on. The solenoid for the dash heat and ac may be in that bay under the black plastic covers which may be labled " Freightliner". There is a blower motor resistor or relay behind a panel on the pass..side dash, a row of sq. sq. plastic relays..Look for one labled IGN or ACC. Your dash fan and A/C compressor clutch power run through these ignition switched relays.
