2017 Roadtrek Adventurous XL
Sadie2017
Greetings Roadtrekkers,
Looking for info on the plumbing system in the 2017 Roadtrek Adventurous XL.
I have located what I believe is a plumbing vent pipe, on the roof of the passenger side of the RV, above the sliding door. It is to the right, (toward the front of the vehicle) of the bathroom fan cover.
1. If this is the vent pipe, what tank or tanks does it vent: black, or gray, or both?
2. If this the vent pipe, shouldn't it have a cover?
3. I tried to run a small plastic rod down the pipe, in case it had debris in it because of no cap, but it came to a hard stop after about an inch or two. Is this normal?
4. If this is the plumbing vent, I will run water down the pipe to ensure it is clear.
Any information, advice, or recommendations will be greatly appreciated.
Regards,
Sadie2017
