2018 Pursuit Precision 29SS retractable step/hood stay
Tiger955
Alberta, Canada
Canyon Star 3205
32ft
W20
8.1 l Chevy Vortec
Can anyone supply me with a photo of the hood stay, how it is mounted & operates please, a good friend has just purchased a Pursuit but the dealer (Woody's Calgary) wasn't able to replace this missing item!!!
Also the retractable entry step only retracts when the ignition is turned on (it extends when door is opened but does not go back when it is closed, ign. off) is this the correct operation?
There is often a switch which will let the step stay out when the door is closed, in one position, and allows the step to retract when the door is closed, in the other position.
Hi AbdRahim, yes mine has that but can't find one, well there is a switch next to the boot locker light switch we don't know what or if it works. Maybe a wire has come off it. I don't know what make the step is yet so as to find a wiring diagram.
Try the switch. See what it does
It didn't do anything that we could see, certainly didn't do anything with the step operation. When given the walk through by dealer, (who didn't know what the switch did!) the engine was running so the step went in / out with the door opening / closing.
Could that switch be a master light switch for the baggage compartments?
UPDATE on step: The unknown switch (on side of stair well paired with foot locker light switch) is the one that is used to hold the step out. What I don't understand is with the battery isolator switch On it works as it should but with it Off & the step is out, the step stays out unless the ignition switch is turned on then the safety feature kicks in & retracts the step.
Where does the step get it's power from, the house batteries bypassing the isolator or the engine battery & the control unit is powered from the isolator?
So to leave the RV with the step in, you have to close the screen door (to retract step) reach in through the small sliding door in screen & turn the isolator off! (or turn off the isolator before opening the door, then jumping out!)
Thoughts anyone?
Also still would like a photo of the hood stay.
UPDATE 2: On re-entering with the isolator off, opening the door extends the step! So if it extends why doesn't it retract with the isolator off?
Wait one moment sir why I call the factory and find out what is does so you can get the full benifit of your purchase from my fine establishment🤣
That is why I prefer manual or no step and no rooms that expand into sign poles. Can you trace the wires from the step motor and controls?
