2022 Tiffin 35CP Closet Lights
2022 CP35 Polodog
Hello
The closet lights are remaining ON in our close, can't locate a switch and master lights all OFF except closet.
Any ideas for shutting off?
Thanks
Look on the light base itself, on mine there is a switch to turn the light on or off. When turned on, they come on automatically with a sensor. But if running the air or heat at night some times they come on by themselves. I think power fluctuations sets them off, but that is just a wild guess. The switch turns them off all together.
HH
Look on the light base itself, on mine there is a switch to turn the light on or off. When turned on, they come on automatically with a sensor. But if running the air or heat at night some toms they come on by themselves. I think power fluctuations sets them off, but that is just a wild guess. The switch turns them off all together.
HH
Thanks, light base, where specifically?
The closet lights are mounted to the ceiling like on a little plate. It's hard to see but there is a switch on that plate. Run your fingers over the plate until you feel the switch. Turn them off. When they turn on by movement of the closet doors they should stay on for like three minutes then turn off by themselves.
Jim P.
Thanks, the ceiling lights are just pucks with no visible switch and nothing on lighted closet bar. I appreciate the response, thinking switch is missing or I'm going crazy.
Thanks again
