2022 Xite NavNGo - MAPS
FLSteve
Fort Myers, FL
New Aire 3547
35'
Freightliner
2024 JL Rubicon
I know if everything is working property you should get a message when updated maps are available for WiFi download. In the meantime, is there any way to confirm that the unit is using the latest maps? Here is a screenshot of my maps that I downloaded back in May. Does anyone know if this is the latest version?
FLSteve :unsure:
Check with ARD, she seems to have a good grasp on that.
I just downloaded the map. I have the same version.
Thanks @ARD ... good to know that things appear to be working correctly.
FLSteve (y)
@ARD @redbaron ... I received a notification this morning that new maps were available, so I just downloaded and installed them. This is now the latest version.
FLSteve
not trying to hijack this thread but on my 2022 LA the nav system reboots every so often as I am driving down the road.
thoughts as to why?
thoughts as to why?
I have the same problem with my 2022 DS. After a while, it quit getting a signal. I spoke with Xite, they said more than likely the issue was the satellite antenna wire, antenna or both. They said if that wire is shorting out it will cause the radio to restart. Unit at the dealer now for this and other items, hopefully they fix it
Does anybody know what the latest map update is? I just downloaded these (Release 2022 Q4) and hope they are the latest.
FLSteve :unsure:
Interesting since our Superstar was doing the same thing periodically on the trip up from Florida.
Not using navigation in the unit but started it up a couple days ago to check it out and it wouldn’t acquire the gps satellites.
May be time to pull it out of the dash and check the wiring.
Update on my issue, they had to replace the antenna and head unit. They first tried the antenna, nothing changed. Then replaced the head unit but used old antenna, still no signal. Finally replaced head unit and antenna and finally got a signal. Now to see how long the fix works
Thanks for the update.
Planning a trip to the factory before we head south again so may have them check it there.
