2023 Freedom Express 274 RK
RCIII
Colorado
Coachmen Freedom Express
274RKS
31’10”
2020 F150 XLT
Recently purchased and trying to winterize the unit. Where is the water pump located and where the water heater by-pass valve. Shouldn’t be that hard but I can’t seem to find them.
I have a different model than you but my water pump is under the kitchen sink.
I’ll take a look tomorrow but that’s a long way from my fresh water fill point. I would think it’d be closer to that area
If you activate the pump, you should be able to pin point its location. Ours is under the sink under the bottom panel. Not sure on the heater by pass. Likely in the same area.
Coachman may be able to help you with the location. They can look up by Vin#.
Yeah, I’ll do that but I’d think an access door would be noticeable. Thanks
You may not find any bypass valves. You may need to install yours aftermarket!
quit looking for access doors, and look for access panels!
Panel/door-same thing. No by-pass sounds unusual IMO. I typically blow out my campers but i have added antifreeze too.
