2023 Nexus Wraith 34W 120v Outlet Issue
MonkeyBasket
My 120v Outlets in the bedroom and living room are dead. The Bathroom a GFCI outlet works and is linked to the single outlet in the kitchen which also works. The exterior GFCI located by the outdoor TV works but the outdoor TV outlet doesn't work. From what I can tell all these outlets minus the bathroom, kitchen, and outside outlet are wired into one giant gang in a junction box under the bed and fed into the power distribution panel. I checked all the fuses and breakers with no luck. Is there another GFCI outlet somewhere that Im missing or something else I am not thinking of? The inverter says its fine. I was on 50amp shore power and overloaded the outlet by stovetop range. I say overloaded because as soon as I plugged in the toaster the outlets in the bedroom and living room went dark.
