A low point drain valve is leaking - the body of the valve
Marius Perron
San Antonio, Texas
Grand Design
Solitude
I have a 2020 Grand Design Solitude ST382WB-R, VIN: 573FS4328L9905779. A low point drain valve is leaking, but it is difficult to know the best way to fix it.
This video shows my problem -
I would appreciate any help.
The video did not open so I can not tell the type or where they are. If you can access from under the rig you should be able to replace some what easily. Ours are assessable from inside and have done this before. I open and closed a couple of times and it was fine. Good luck!
