A simple, but painfully hard to figure out Oasis problem
newmarokie
southern oklahoma
newmar
Dutch Star 4018
40'
450 hp Cummins
2017 Colorado, 2013 Dodge 1500 quad cab
OK. Had the coach out last weekend for a ballgame. We tried to fire up the oasis for some heat. It sputtered a couple of times and then quit even sputtering. We got to plug in eventually and the AC side kept us from freezing Saturday night. Got home and tinkered with it. Opened it up and cleaned the nozzle, stem, and filter. No joy. Got it moved to the shop on Monday and really dug into it. Checked the solenoid valve. It was functioning. Checked the ignitor, it was good. Checked the flame sensor, it was working. I disassembled the regulator, it checked out. In studying the regulator I realized the back side is open to the atmosphere. I could take a #6 machine screw and gently push in and the burner would get fuel a fire up. Pull the screw out and the flame went out. OK< I'm stumped. I call ITR and visit with a tech. I didn't get his name, but he enlightened me on a thing or two. The regulator works off of vacuum. The burner draws the fuel to itself from the venturri created mixing the fuel and air. He said the system would work with the fuel line dipped into a cup or fuel. Hmm. I took the fule line loose and put it in a cup of fuel and tried to start it and the fuel line was blowing bubbles. Not good. I finally found the right size O-ring to replace the old one on the stem. Still didn't work but just a few bubbles. OK, maybe I need to tighten the stem into the tip. Worse bubbles. So I took the stem and nozzle out of the tip and put a 5/32" x 9/32" x 1/16" O-ring on the nozzle where it sits in the stem. There was not any sign of one there when I took it apart. Run it up in the tip good and snug. Reassembled everything and it fired right up. About forty cents of parts and six hours of labor and it is working. Does anyone know if that last O-ring I put in is supposed to be there? It could be that my nozzle and stem are worn and just not sealing good. I have searched for a good schematic to no avail
I am not following where the o-ring was.
But do know that when a tiny o-ring on the stem failed for us in the past that the burner would not work.
We carry spare o-rings now, super cheap.
Memories, there is an O-ring at the bottom of the stem where it goes in the burner body. It separates the air from the fuel until it gets to the nozzle. I put a very small O-ring between the tip and the stem. I was losing air there and putting back pressure on the incoming fuel. The same result as the O-ring at the base being bad. I did finally find a service paper on this on the ITR website. It doesn't show or talk about an O-ring at that end. My thoughts are if it fails the burner quits working. If it doesn't fail, Yah!!
Have you tried calling ITR?
OSU, I haven't called ITR since I got it working. I did talk to them earlier on. I have run the unit for about four hours to see if the O-ring would overheat and degrade out. It is still good at this point. I did a little digging on service kits and a new nozzle comes with a five year kit. My coach is seven years old. It is probably time to replace the nozzle. I think at this point I am going use it as is and order a nozzle from Newpar. If/when it fails, I can put the new nozzle in in about forty five minutes. The nozzle is $189 from Newpar. ITR doesn't offer the nozzle stand alone, but the difference between the three and five year kit is ninety dollars. I am going to call ITR and see if I can purchase the nozzle stand alone.
I don’t know if you tried this source but this is where I get most of our Oasis maintenance parts now.
When we replaced the nozzle I kept the old one, cleaned it up, and when I service the unit every year I swap out the nozzle, putting the clean one in and then will clean the old one and put it back in the parts bin.
Been replacing the o ring every other time I do a nozzle swap.
I buy from hydronicheatingwarehouse.com as well. A nozzle is $85 there. More than $100 less than Newmar.
Neemer, do you have to call and order the nozzle or is it on the website? I am not seeing it on line.
got one ordered. Thanks Neemer. Memories, Yes that is where I got my three year service kit
