Question AC thermostat question
KJ2019RoadtrekZion
Hello All Roadtrekers!
I noticed today our Dometic thermostat was causing our AC to run non-stop by it not being able to reach set temperature. Even though the set temperature in the RV was reached. After doing some studying of the matter I believe I determined what is causing the AC to constantly run.
The thermostat is on the wall of the side of the camper that is facing the afternoon sun. Additional note, this campground is one without trees or any form of shade. When I held my hand up to the side window adjacent to the wall holding the thermostat I could just feel the heat radiating through the window. I went outside to study the outer area of the Roadtrek RV and notice the other wall is where the full panel tinted black window is located directly outside the wall where the Dometic thermostat hangs on the inside wall too.
So, my determination is the heat from the sun pounding on those outer windows with no shade or trees to protect those windows is skewing the thermostat in getting a higher temperature reading than it actually is inside the camper. Thus determining the AC does not have the RV up to set temperature.
I’m thinking of placing a sunshield on that adjacent inside window to help some.
Did anyone else notice this issue, and if so, curious to know what you may have done to resolve the issue of the thermostat running the AC non-stop because of skewing the temperature in the RV from the sun radiating heat through the window adjacent and wall behind the thermostat.
Thank you in advance for any suggestions.
This may not apply to your unit, but on our 2006 190 Popular the camp shade is on the same side as the thermostat, the passenger side, so the window below the thermostat is shaded when we are camped. There is storage above the thermostat inside the fiberglass top, which we happen to use for clothing, so there is some "insulation". At present, we have the same problem as you do. However, we think the AC is not blowing very cool air and may need refrigerant. Our local hero says that he may be able to add service ports and recharge it, but has gone on a vacation! Would you like an update in a month or so?
If you're thermostat is set to hi or low speed it will run all the time but only engage the compressor when needed. If you set the thermostat to auto it will only turn the AC on when cooling is required.
Move the thermostat.
I have had this issue when the RV is at home. It’s under a pole barn, but the morning sun hits the thermostat side.
I just run the set temperature up a few degrees…
