turbopilot
- Nov 2, 2019
- Prescott, AZ
- LightShip
- AE.1 Cosmos
- Electric
- 2025 Ford F-150 PowerBoost HEV
Comparison of Electric RV Specifications
The LightShip AE.1, Pebble Flow, and Evotrex PG5 are all advanced electric travel trailers designed for efficient towing, off-grid capability, and modern amenities. They feature battery-powered systems, solar integration, and propulsion assists to reduce tow vehicle strain. Below is a side-by-side comparison of key specifications in a table format for clarity.
Specification | LightShip AE.1 Atmos | Pebble Flow | Evotrex PG5 Atlas |
Exterior Length | 26' 7" | 24' 8" | 28' 8" |
Exterior Width | 8' 5" | 7' 7" | 8' |
Exterior Height | 6' 11" (Road Mode) / 10' 1" (Camp Mode) | 8' 9" | 9' 5" |
Interior Dimensions (L x W x H) | 22' 7" x 7' 4" x 7' 5" | 21' x 7' x 6' 5" | 22' 11" x 7' 2" x 6' 6.74" |
Dry Weight | 7,200 lbs | 5,800 lbs | 8,900 lbs |
GVWR | 8,200 lbs | 6,800 lbs | 9,900 lbs |
Tongue Weight | 792 lbs | 680 lbs | Not specified |
Water Tanks (Fresh/Grey/Black) | 50 / 35 / 30 gal | 40 / 37 / 18 gal | 60 / 30 / 30 gal |
Battery Capacity | 77 kWh (LFP) | 45 kWh (LFP) | 43 kWh (LFP) |
Solar Capacity | 1.8 kW | 1.1 kW | 1.5 kW |
HVAC System | 20,000 BTU High Voltage Heat Pump with Drive Train Heat Scavenging | 15,000 BTU Heat Pump HVAC | 17,000 BTU HVAC |
Self Propelled System | TrekDrive™ self-propulsion 20 kW(Peak 70 kW) | Magic Pack Self Propulsion | Active Power Assist Self-Propulsion |
Off-Grid Capability | 7+ Days | Up to 7 days | 7+ days |
Sleeping Capacity | Up to 4 (optional Summit sleeper for more) | Up to 4 | 4 (two queen beds) |
Key Features | Auto-leveling, panoramic windows, dishwasher, induction cooktop, LookOut cameras, home backup power, Starlink Integration | Magic Hitch auto-hitching, InstaCamp one-touch setup, Starlink integration, quiet HVAC, tankless water heater | Terrece™ rear patio, dynamic skylight, projector screen, zero-wood construction, remote parking, tank heaters, Horizon Generator |
Price (Starting) | $184,000 | $139,500 | $159,990 |
