ajverhagen
- May 7, 2021
It takes about a minute to fill the tank from empty. on the harbor freight unit. how many cf are in a 22.5 tire? The draw back of it would be the 110 vac power supply requirement.How long does it take to inflate a tire that that needs 100 psi if the tire is down to 80 or 90 psi ?
I use a rule of thumb for the higher PSI tires of 1 psi per minute otherwise I'll get anxious.How long does it take to inflate a tire that that needs 100 psi if the tire is down to 80 or 90 psi ?
