Aquahot
Tonanickle
I’m at my wits end! We have 2022 Entegra accolade 37k and my showers are dreadful. The water is hot for 2 minutes only. I hear my Aquahot working and firing up but, several times during the duration of a 10 minute shower I have to shut the water off and wait 30-45 seconds to get 1 minutes of hot water. And I do this on repeat for the duration of the shower. Has anyone else experienced this? My husband suspects the mixing valve isn’t functioning properly.
What model Aqua hot? Is the hot water heat exchanger separate or inside the main fluid chamber? If the later I would suspect the mixing valve or there is another cross connection in the rig somewhere. Could be the mixing or stir pump. How about the flow rate? If using campground water at a higher, pressure flow rate, and colder water coming in you will get lower performance. Many of the AH units are only rated 1.5 gpm.
Dennis
