Awnings when it’s windy
Donaldduck4
Tiffin
Allegro Red 33AA
Cjj is mmjns
Dolly
I’m new in RVing ! I’m wanting to keep my awning open with my sunshade on but because it’s windy it keeps closing ! What can I do ? I’m facing the sun in the morning and in early evening , yuck ! Help please ?
DD, Please update your profile, so people can see which RV you are talking about. Without your RV info, not likely someone will try to help you.
Click/tap this link to update your profile. You can also reply and attach a picture of your RV and awning so we can see what you're using. Welcome to RVForums.com.
Ok , profile is done and Thank You
Profile is done and Thank You !
I'm not sure what type of awning you have, without seeing a picture, but my guess is it's like mine, a CareFree. I'll link to the Vista Shade attachment that may work which would allow you to tie it down. But you are asking for trouble regardless, high winds can tear the awning right off your coach and you'll be paying a pretty price for a repair. It's best to use awnings with little to no wind. They typically have a wind sensor, mine has 3 settings (low/mid/high) for sensitivity (or wind speed handling). Just apply a little common sense and save yourself a lot of money. They are fragile.
Mines a Girard , I’ll check to see where the settings are at and Thanks
If the sensors shut it leave it shut until the wind dies down. I have seen them ripped off of campers by the wind. Really ugly and expensive to fix.
Also, don't leave them open, while you are away while shopping in town, hiking etc. My awnings almost useless. Rain will fill them and they can collapse. In the slightest wind I can see them starting to sway up and down. Constant PIA.
We have had our motorhome going into the 3rd summer. I can count on 1 hand the times the awning has been out. It makes me really nervous to watch that thing bounce with the smallest or breeze. Its a power awning so no real "arms" to support anything. Looks like a big sail to me. I am paranoid about the thing flipping over the top and someone filming it for an insurance commercial.
Ken
My awning ended up on the roof this past winter. Small breeze, I was right there. A small gust came up and it billowed in the center, I ran over to put it in and it was already on the roof.
Neighbors at the resort helped me reattach it after I got the fasteners and tape I needed.
What I found: That awning arm had been attached with rivets instead of screws at the bottom. Rivets into a solid wood block. The sealing butyl tape behind the support hadn't had the paper peeled off of it so it was doing no sealing at all.
