Backup camera
ynot
tiffin
32sa open road
ford
ford
Hello all
I have a 2018 tiffin open road 32sa
Have issue with my backup camera
Sometimes it goes blank and fading
I turn the ignition off and on it work for few seconds than goes blank
Any advice ?
Thx
It sounds like the camera itself is failing. It seems to work when the power hits then fades. So a loose connection or faulty wire seems not to be a case. I had a side camera come on and fade then completely stop.
Your connections are under the dash. You can pop that cut out at the top of your console on the dash and check most of them out and pop slide your hood to see them. My solution was a new camera. My coach was at Red Bay for service and had them install it.
HH
