Rustymayes
RVF VIP
- Sep 11, 2022
- Vacaville, CA
Ok. I came up with a permanent and elegant solution to the snap ring hinge issue. I found some Oil Lite flanged bushings at McMaster Carr. The machined flanges will carry the load of the door and the bronze bushing will last forever and a day. Unfortunately, the closest I could find were 5/8 OD which is .016 bigger than the boss in the hinge. I had to chuck them up in my lathe and turn them down to fit. I also had to add a couple of 3/8 flat washers to shim the door the perfect resting position. The door is at least 50 percent
more stable with the tighter tolerances.
3/8 washer on each end of the plastic spacer to shim the door.
My set up to turn the bushings down. A 3/8 bolt long enough chuck up. This could be done in a drill press and a use a file to shave down the bronze if you are careful.
This fix will end up costing me less than ten bucks a door. I could machine a snap ring groove in them to use for the doors that drop down. The only one that does that on my coach is the wet bay door.
