The lights will dim and fans are weak, the level indicator lights will say what level the batteries are at and we put a voltage meter on the batteries they will range from 7 volts to 11voltsHow do you know how full the batteries are?
The problem is when we are plugged into shore power the house batteries won’t hold a charge everything works fine when the motor home is running. We have been letting run to charge them up then they die a day later.alternator should be charging at 14 v.
The pole is fine all 120 is workingCheck to see what is happening at the pole. Problem could be outside your coach.
7v with the motor running is blow
. After we replaced the converter we charged the batteries outside and they didn’t hold a charge they were 5 years old so we replaced them with new batteries and still having an issue12vdc is a dead battery at rest. That said most inverters shut down at 10.5vdc,because under load that is the magic number indicating 50%charge. With the same breath I will state, at rest a voltage of 10vdc indicates a dead cell, and 8vdc would indicate two bad cells.
Charge the batteries out of circuit for 24 hours. With batteries disconnected check voltage. That voltage after a couple of hours should read around 12.67vdc. In another day they should read much the same. If they don't record the voltage you just read, and measure again the next day. If they are down even further the battery has at least one maybe two shorted cells.
