Battery Questions
Zman300
Oshkosh, WI
New Aire 3343
34'
Freightliner XCS
Cummins 360HP
None
Have a 2018 Newmar New Aire 3343.
This rig is completely different from our previous Georgie Boy Swinger.
A ton more gadgets with electrical draw.
The previous owner said it likes to be plugged in to shore power.
Does it have to be all the time?
I left it unplugged for a few days, now it is completely dead.
It's been plugged in to a 110 out for about 24 hours but it is still dead.
That's all I currently have available.
I can install a 50-amp outlet at home.
Problem is, our storage unit only has 110 available.
Is that going to work.
Our RV adventure isn't starting out too good.
Didn't have many problems with our previous RV.
Towards the end had a few that were very frustrating.
This is bringing back bad memories.
Hope I don't regret this purchase.
Thanks for any help you can provide.
110v should be fine…need to look at the inverter/charger and make sure it is charging….and not at too high a rate or it could blow the breaker on the 110 outlet.
And try to shut as many things down as possible including the 12v load via the salesman switch.
Your inverter's charger may have a minimum voltage required for the charger to begin charging. The Magnum we have does...so, you need to jump the battery to raise it to this minimum level...at which time the inverter charger will go back to work.
If you need to unplug for more than 24 hrs...consider auto gen start or adding solar or both... There is a finite number of aH in the bank...and it needs some form of charge, beit driving, generator, solar, or shore power.
I have a lot to learn, not sure what the salesman switch is.
It has a solar panel, but from what I've read it doesn't put out enough to do any good.
Saleman switch is the House DC power relay control switch by the passenger side on newer coach's that cuts a portion of the House DC circuits. Useful for momentarily removing power from some microprocessor circuits to reboot them...and useful for RV dealers to quickly isolate lights, water pump, fantastic fans etc... when they leave after showing a potential buyer the coach.
The stock solar is usually a 10A...but Newmar has used 5w and 20w as well. The 10w is direct connect thru an inline fuse to the chassis batteries...and yes, it is worthless. I wouldn't go less than 400w for a simple battery maintainer...and more like 1600w if you want to keep the fridge powered...but it does depend on your latitude, time of year, temperature, breeze, and shadows/obstructions...
