Duffyonthemove
- Oct 23, 2022
If there is no circuit it shouldn't hurt anything. A cutoff switch is preferred to safely break a circuit but as long as you protect the connectors so they cannot create a circuit or ground you should be fine. But ask why you really need to remove a battery.
Pretty much. What year? If it’s recent and has a disconnect you can just use the disconnect to isolate the rest of the unit.On a related note: if the only thing running off the battery are the radio and to CO detector, I don’t need to worry about battery drain if there’s a solar panel attached?
Keep the panel clean of solar and you are good to go. Check the battery voltage from time to time.
If it’s a trailer it may be on the tongue or in the front cabinet. Usually a big red knob.It’s a ‘22. What would the disconnect look like?
I want to use the battery in another RV which we drive to Florida for the winterIf there is no circuit it shouldn't hurt anything. A cutoff switch is preferred to safely break a circuit but as long as you protect the connectors so they cannot create a circuit or ground you should be fine. But ask why you really need to remove a battery.
No need as long as the panel is getting sunlight to keep a charge. It acts somewhat as a trickle charger IMO. I have never disconnected a battery to remove from our campers and never a issue. I can see this if one parks their camper under a cover where sunlight could not hit a solar panel to keep the battery maintained or the camper has no solar panels and the battery is just that, alone in the fight. Then yes, I would place on a trickle unit.On a related note: if the only thing running off the battery are the radio and to CO detector, I don’t need to worry about battery drain if there’s a solar panel attached?
