I have a dp motorhome. It has 2 house batteries & 1 engine battery The house batteries are hooked together. I plan on running jumpers to the engine battery. I want to put a Battery Minder 2012 on this system while it is stored. Can I run both the motor home charger at the same time as the Battery Minder, or should I disconnect the rv battery charger.
When I run the jumper wire should I connect it to pos house battery 1 & neg house battery 2. Or should I just use 1 of the house batteries to engine battery?
Thanks for the help, captwheel
