Bdrm TV
tashatara
ResrbTV in 2019 Tiffin bus will retract on its own with no buttons pushed or no movement inside of bus. Is this a wiring short?
I would check remote to see if it may have a button stuck. Pull the batteries to reboot it. If not check the plug to insure it is plugged in all the way as that could cause this. Also would suggest unplugging for a couple minutes to reboot this as well. If not that I am guessing it is the internal to the TV
Also, check for a loose wire/bad ground on controller wires
