Question Best bug cleaner remover
Not happy with bugs-n-all. What are you all using and happy with?
Shinesupply.com
This stuff works better than anything I have ever seen, and is ceramic and ppf safe.
Probably cannot do it, but it would be nice to have something to just add to the WW fluid.
This spray goes on, and then I use a garden hose to remove bugs.
I use a garden chemical sprayer with 90" extension to treat the windshield. Makes life so easy.
i use soften water. Let water soak the bugs and they will wipe off. Key is to get them off before they bake on. Central Florida Love Bugs
I spray the front down with PAM. Yep, cooking spray. The bugs and their remains will easily wash off. Overheard: "do you know what the bug said that hit the windshield? Takes guts to do that again".
I use wet dryer sheets on our Class C.
Shinesupply.com
I used this today for the first time. Been using (trying) bugs-n-all in the past. This stuff is much better! Thanks @redbaron
I use good old fashioned elbow grease.
Just got done with my cleaning.
A few tips:
Only clean when it's cool and the sun is going down. Sunset and the following 30 minutes are perfect. Also dawn is a good option.
Clean within 12 hours of initial contact if possible.
For a quick clean, I spray the bugs and let soak for 60 seconds. I then use a bucket of water with a microfiber and go over the bugs in a single motion, changing sides of rag and then rinsing, wring towel, and repeat.
The bugs come off with ease. For the windshield, I spray the bugs then use the truck stop window squeegee and solution.
Giving it time to soak makes the job very easy.
I did it before the sun hit it, late morning. This is the first time I've been able to spray on a bug cleaner, wait a minute, and simply hose off with DI rinse. No bug scrubbers, or any interaction with the front end, no ladders, nothing. Spray, wait, hose off. Winner!
This post is 4+ years old.
Are y'all still happy with your preferred products/procedures?
Leaving on a trip in a few days.
Tempted to lightly spray Pam on front end as a preventative.
Anyone still using Pam??
Don't spray cooking oil on your coach, put a nice coat of carnauba wax on it, just the front shouldn't take long.
I've already got ceramic on it.
Yes. I have now upgraded to a 3 gallon pump sprayer with a 36inch wand. I also have the hand sprayer for the front end paint area at my level. With this setup I actually enjoy cleaning the coach each stop
