Question Blue Tv
Kwdaye
I am new here and to the superbox, I was wondering what’s going on with the Blue TV APP, it keep just shutting down and going back to the Home Screen, the rest works fine.
Thank you,
Kevin
Thank you,
Kevin
Veesee box is SO MUCH BETTER! I have both and I experience the same "back to home screen" issue. It's not a huge issue, but it was enough that I joined a Superbox FB group looking for answers, and that's where I learned about the Veesee. The Veesee is so superior in so many ways, that I'm buying them for my house, RV and my RV Lot.
Try it, you won't be disappointed!
Amazon
The more I use and look for stuff on the superbox, I am noticing that there’s several movies and shows that I’ve looked for and are not on there, just wondering if there’s more stuff on the Vsee box
Yes, a ton more! Part of the beauty of Vsee is how it's organized. Very easy to find what you're looking for.
Okay educate me🤷‍♂️
What does this box give me?
Well I have until Jan 31st send the superbox back to Amazon, I might just send it back on the 30 and try the Vsee
Amazon
I've had a Superbox S5 Max since February and have found it very easy to use, easy to find movies & TV shows and no operational (software/app) issues. Even figured out how to change stream rate to accommodate using my Visble phone for streaming while on the road. At home, it works equally as well using WI-FI or an RJ45 connected directly to my router. It has pretty much the same channel line up as the VSeebox, only noticible difference seems to be the TV guide layout. Superbox firmware and apps are updateable, hardware specs are similar between the two, I can add a DVR, so what's the difference other than costing about $100 more?
Probably not a lot when you put it that way. But from an operational perspective, there are some features that make the Veesee so much nicer to operate.
Here is a snapshot I just took. Unfortunately, there are no NFL games on today, but if there were, you would see them listed on the right. Same if you wanted to watch college football. Just arrow down to the type of sport you want, and on the right are all the games you can choose from.
Just one of the reasons that I prefer the VeeSee over the Superbox. Oh, and the irritation that comes from having to deal with it when it decides to snap back to the home menu. And yes, I see you aren't having that problem, but many of the rest of us are.
