Both of my toilets in my 2023 Holiday Rambler 35 K dont work?
No clue what could cause that. I take it you are just not getting water to the toilets or are they both clogged?
We are at a campsite and attached to their water and out of the clear blue our toilets do not flush? Nothing?? Help??
Do you have a specific valve ibn your wet bay that directs city water use? My wet bay has a valve for dry camping, city water, fill, flush and winterize.
Meanwhile, fill a jug, bucket or empty plastic coffee container with a quart of fresh water, let the toilet do it's straight drop into the waste tank, rinse the bowl using the quart, drop that rinse water thru, then add an inch of water cover over the closed up valve.
If your sink faucet runs water that goes on to be in the grey tank but your toilets cant, maybe your black tank level sensors are signaling full (whether a true level indication or not) and disabling more water going down.
If there are no turns in the pipe under one of the toilets, try to look down through the open valve to see (use flashlight) whether the black tank control panel level indication matches reality.
