Brake Buddy
Fatboy2004
RVF VIP
Winnebago Itasca
Sunova
35 foot
2015 Willy's Jeep
I'm setting up my 2022 jeep for towing. Installed the new base plate and all went well. Of course the one off of the 2015 is different. I removed the old brake-away switch from my old jeep. I have mounted and ran the cable to the front seat. Do you pull the cable to test it and does it just push back in. Remember no question is a dumb question .Next week the lights. Double pig tails because the 2022 Jeep did not come with a trailer hitch which I have already installed.
Thanks in advance.
Thanks in advance.
I do test ours every couple of months now. I use a test meter to make sure there is a closed circuit when the plug has been pulled. It should reset to open circuit once you insert the plug again. I had a problem a couple of years ago. The plug would not reset. I had to take the unit apart since I was no where near an RV Store to buy a new one. It is a quite simple unit. I discovered the spring that holds the plug in place had rusted away. I found a replacement spring and it is still working fine.. Rather than spending $100.00 on a new switch I now just check it more often.
Darrell
Yes that s correct. Make sure unit is powered up and the unit in the RV is also powered up. I may have been guilty of this one.
