Thank you. I'll try it.They are very difficult to use. We never use ours due to this problem. I even lubed the swivel mechanism up when I had the seats out last year when I was installing sound and heat barrier in the cab under the rubber matting.
This is for the E-450 based Foresters: While sitting in the seat, put the seatback in the upright position, pull that yellow handle out (it pivots on one end), the seat will slide diagonally toward the center of the vehicle. Once you have it slid, you can then swivel it around to face the rear of the coach.
Thank you I was able to do it! Hope it's not hard to get back....Thank you. I'll try it.
