Cabelas tabletop grill
PilotKev62
Oakland Tn.
Fleetwood
Southwind
Chevrolet
Workhorse V8
Along with the Fleetwood southwind RV I acquired from my parents who are too old to drive. It came with some things they used on their trips. Ind was a portable table top grill from cabelas’s . Used the one pound disposable propane tanks. I decided to use it at the house to see how it works.
Well at first even on high the regulator would not allow enough propane to allow proper cooking. I found that under the regulator knob sticker there is an adjustment that can be made using an Allan wrench. I turned it clockwise and the flame gets much higher and it works great after that. I’m going to purchase an adapter hose to connect to a 20 pound propane tank instead of buying or refilling the 1 pound tanks
I thought this might help someone who is in the same situation. Maybe it comes that way as a factory setting and in the instruction manual it may tell about this but I don’t have that.
I am not sure how your rig is set up but when I bought our Blackstone Grill/ Griddle I converted it to run off our coaches main LP tank. I ran a new gas approved line and fittings so I can just plug the grill in and go.
