- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
YES! I've done it three times!
I remember prior to ordering my coach my salesman mentioned the macerator toilet as something that you could put anything into it like it was one of the monster wood chippers. I learned the rule from someone somewhere early on is nothing goes in the toilets other then body stuff, i.e. no gum, etc. Well, I was surprised to see my dometic macerator toilet actually get clogged and now it's happened three times. The cause? KLEENEX! There must be something in the oils in kleenex/puffs etc. or that the tissue itself is a bit strong that it wraps itself around the blades, who knows. Since never putting kleenex in the toilet and instead in the trash can I've never had an issue even with what may be times of concern with excessive TP. I've also heard issues when people use the water saving mode but I never use that. I want a good flush with all the water to chase it that you can.
So now the question, how to clear the clog. There is no plunging as the valve is closed when the flush action is not in use. Time is on your side. Hopefully you're using the scotts rapidly dissolving RV toilet paper I get from amazon. Let the TP or whatever have time to dissolve and a flush a few hours later may actually work. The other option is to turn off your water and get a plunger. With the water off now trigger a flush so the valve opens and try plunging. I've also added draino (it is safe for plastics) but you should probably flush several times and dump the tank if concerned. The first time I had to take a bucket and transfer the nearly overflowing toilet to the other toilet I'm fortunate to have and also glad it's a gravity drop and not a macerator but it's still near puke worthy.
The moral here is yes you can clog a macerator toilet and do not put anything in it other than toilet paper!
