Captain's Chair
Garry.Bergstrom
Lake Worth, Florida
Bay Star 3225
Buick Encore GX
Newbie question. 2021 Bay Star sport, took delivery in May. Brochure shows driver chair rotated around to face the living area. After much finaglingng, I am unable to get it fully around. Hangs up on steering wheel. Tips or solution? Thanks
I have to start to rotate and then move my seat forward. You may also have to raise your steering wheel which is probably preferred anyways in this mode.
Hi Garry
All these chairs can be a PIA. Make sure your steering wheel is tilted up all the way. Move the chair BACK all the way away from the steering wheel. Usually their is a latch that you pull up to release the chair to spin. When spinning the chair move to the inside of the coach. Hope this helps.
HH
@Garry.Bergstrom ... There is also about 50' of extra wire under these chairs all waded and tied up so when you spin it around make sure that does not get hung up. I pinched a wire one time and it blew a fuse.
FLSteve :)
FLSteve :)
Got that tee shirt as well in our Canyon Star. It helps you learn the location of fuses when things go flash in the night.
And also remember to check the slide can come in without tearing the chair out of the floor if it is in the wrong position. So far have not turned either seats around, and reluctant to do so with all the issues involved. But make sure it not going to get hurt.
