longfellows4
- Jan 9, 2023
It would be cutting into the 2 inch panel support piece as show in picNot sure what you are asking....inside what particular piece are we talking about?
I’m just cutting like a 5 “ x 5 “ area in it, just worried about any electric or gas etc lines inside the panelCan you cut the door under it and leave it intact? the wall on either side will be very weak. The bed won't collapse it but it will not retain it shape well. Cutting the bottom one would be better.
I think that is a good idea to drill a small hole and carefully inspect as I go, shutting the power down of courseSo there is another piece of luan inside the framing? Usually they don't finish the inside compartment. If there is, cut a small hole, carefully, and then enlarge it as you go. Start with a drill and dont just shove it thru the wall, try to just penetrate it at first.
I did it and it is awesome, a great day and great way to allow the cats some additional exploration and have the cat box out ofSo there is another piece of luan inside the framing? Usually they don't finish the inside compartment. If there is, cut a small hole, carefully, and then enlarge it as you go. Start with a drill and dont just shove it thru the wall, try to just penetrate it at first.
