Changing out a crank out window
mansracing
Rogers,MN
Essex 4531
X15
Stacker Trailer
I have a 2018 Essex and the pass side lower crank out window needs to be replaced.Anyone know what the procedure is to change this out?
Thanks
Randy
I changed out two crank out window frames on the main cabin window, where the upper is fixed. Remove the screw holding the knob and then remove the screen. Next, remove the crank, which allows you to slip the arms off of the glass. Go outside and lift the window up so it's at a right angle to the side of the coach/fixed glass and remove. It's a "U" shaped hinge where one "U" interlocks into another. Getting it off was easy. Getting it to line up and go back together was another story. You just have to be patient and keep trying to get the two "U: shaped hinges to align.
