Check engine lights
There probably is - try looking for the “shorting plug“ described in this method:
However its important to understand that regens happen in the DPF and that piece of equipment is mounted after the SCR where your SPN code was generated. Forced regens are important, but most likely will not solve your problem. I would expect your MIL to re-activate after some driving and/or ignition cycles.
I haven’t changed my def filter in my pump but am going to today is it easy to do in screw the cap and pull out the old one
I. Changed my filter today and before I drove it I cleared the codes and drove it about 25 miles and no lights came back on and Rich I appreciate all the information and have you ever did force regen by using the shorter plug and is it fairly simple also the def filter was really dirty and when I first Ed cranked it back up the def tank and pump was making a noise that I’ve never heard but after couple of minutes it stopped before I drove it
Thats good so far and the dirty filter may have been the culprit (would like to see a pic) since it can certainly restrict flow to the doser reducing the effectiveness of the SCR, but you should probably put in a couple hundred miles of local driving to make sure the problem is resolved before setting out on a long trip. I hope thats all it was. The different sound from the DEF pump was likely the pump running dry while the system primed itself.
And no Ive never done a forced regen with the shorting plug because I can do it from my ipad with OTR, but I located the shorting plug under my dash and printed the instructions from that link in case I ever need to do it. With OTR diagnostics, I dont have to wait until the HEST lamp illuminates, so I can do forced (parked) regens whenever I want as a preventative measure as long as I have an internet connection.
Pic of my shorting plug, left side under dash next to the OBD port complete with “regen” label to avoid confusion:
While coming home from a trip both of my check engine lights came on but no loss of power checked all fluids and all was fine no over heating and good oil pressure looking for any help
Please click the link in my signature and complete your profile with RV info so the gang here can better assist you.
Here’s a picture of the filter and it appears to alright for now and will be driving about 70 miles today and that shorter plug is it the white harness that you unplug and do you have a program with OTR I saw that you can buy a code reader that does the OTR for 900.00 but I rather learn how to do the shorter plug and thanks again for all your help
Didn’t fix it Rich but I found out that it is Emissions problem and that it is covered under a recall so I’m scheduling a appointment at Cummins thanks again
