Coax cabling for tv’s
Jmetcalfe
Good morning, I have a 2015 allegro bus that I recently purchased that has no tv reception, the previous owner had dish or direct tv and has removed the receiver. Opening the compartment in bedroom under BR tv there is a lot of unplugged cables, for now I just want to get the tv’s to work on antenna only.
If anyone has any experience or can refer me to someone to help straighten this out it would be greatly appreciated.
Thanks in advance
I owned a 2014 AP37 Allegro Bus so know the problem. Unfortunately I sold it in 2020. I recommend doing two things. (1) Unless things have changed for your 2015 (I doubt it), the signal distribution boxes you find in the bedroom cabinet were designed and furnished by the company that sits adjacent to the service stalls in Red Bay. Adjacent to the gift shop. You need to understand what they do and how they distribute to make sense of the system. You can see them using Google map. I spoke with them a number of times and sometimes it took a while for them to call back but they were helpful. Should be able to give you some useful information. (2) the harder way is to go to Tiffin Owner's Forum - iRV2 Forums and see if some one there will pick up on your post. There are some sharp Tiffin owners if they will respond. Just thought of (3) there are a number of mechanics working on the side in Red Bay. Find one, make an appointment.
I'm aware this is an old topic, and possibly resolved now. But I'll post what I know anyway.
Our 2012 Allegro Bus has separate HDMI systems for the OEM Home Entertainment system and the distribution of any satellite system installed. Servicing those 2 sources are 2 HDMI boxes in the basement which must be manually switched on for the programming to reach the several TVs upstairs - they may already be on.
Note that the above is only to explain how home entertainment content and satellite content gets to the TVs, assuming the Tiffin factory system is still in place. The OP is asking how to get OTA TV programming, which is separate from all that.
There's a OTA TV antenna on the roof that does NOT rely on the above distribution system; no manual action is required in the basement for it to work. All that has to be done is to go into the TV's settings and select OTA TV as the source. Then, go through the TV's channel selection option so the TV knows which channels are available.
That should do it.
