Hawkeye
- Nov 24, 2019
- Dutchstar 4018
- 2019 Ford F-150
With Diesel Burner ON and/or Electric Burners (AC I/II) and Furnace on the thermostat you should be fine. I think the wet bay heater is automatic and is not associated to the thermostat at all but it does need a heat source from OASIS being Diesel or Electric burners.
Yes this is correct, but you also need the furnace thermostat set above freezing, I'm pretty sure there is not a automatic thermostat in the wet bay. I'm not sure if there is even dedicated heat ducts in the wet bay or basement.
