Command Center Issue
"EZ"
Internet Forum Junkie since there was dial up!
Ringgold, GA.
Holiday Rambler
Ambassador
40'
2019 Jeep Grand Cherokee
The led display in the hallway of my RV has started to flicker on and off. Sometimes it shows how many amps and the status of the inverter and sometimes it's blank. All systems are working properly it's only the display that has an issue. What could cause this? A loose ground on the display? I'm not very electrical.
This sounds like a ground issue.
That's kinda what I thought too. But I'm no electrician...........
If you can find the ground of the panel, run a clean connection to verify
I'm a YouTube certified electrician: Jiggle it
Does it by chance have a plug in connection on the back. If it does, you might try unplugging & plugging it back in.
Not sure. I haven't tried to fix it yet. Right now everything is working except the command center. I don't want it to get worse in the middle of my vacation so I'm afraid to mess with it. :LOL:
