Converter problem???
Applekrate
I have a 2011 Winnebago Vista 35f
Everything goes dead in coach when unpluged.
Generator won’t start either. Coach batteries are a year old. Water in them good,checked cells with hydrometer,reading good. Power converter bad? If so where is it on this model?
Thanks ,
Barry
Generator motor won't crank? Generator cranks but won't start? I try to start my house portable generators 3-4 times per year and never, EVER run them with ethanol-laced fuel. I can get the no-ethanol fuel around here for about 70-80 cents more per gallon. I despise the ethanol because the ethanol fuel attracts moisture out of the air which then clogs the tiny carburetor jets - - engine impossible to start.
Rick
Aren’t they supposed to be run regularly? Not sure what generator you are talking about, but RV besets are to to be run for at least and hour at half load, once a month. The one on my S&B runs once a week.
