Corned beef brisket
First time smoking one of these critters. 7 hours in the GMG and 30 min rest. Soaked overnight in cold bath. Came out good. Just not my fav meat but it ate.
corned beef brisket is good sliced really thin, otherwise it can be a bit chewy.
The way I see it... Corned beef is a fancy way to sell you a lousy cut of meat. Brisket is a tough chewy cut. It does need to be cross cut with a sharp knife and that appears above in Neil's post.
If you have the time and space in a refrigerated compartment, you can treat yourself to something better. I use the refrigerator in my motor home, when the motor home is parked at home.
Make good corned beef
I boil 6-8 quarts of water
1/4/ to 1/2 cup salt
1/4 to 1/2 cup sugar if you like
2 to 3 ounces of the above pickling spice
4 to 6 pounds of "Spencer Roast" (Next to the shoulder roast(
(You may have to special order from your favorite butcher)
Cut the roasts into 2 to 3 pound pieces.
After the water cools add the meat and refrigerate for 6 to 10 days turning the meat every couple days.
Remove the meat from the brine and add to a crockpot for about 5 to 6 hours. Add cabbage or other vegetables (not potatoes though) at the last 2 to 3 hours. I feel potatoes steal the flavor from the meat.
You may also directly freeze the home corned Spencer roasts for enjoyment at a later date.
There is no food dye in your home made corned beef and you are using a nice cut of meat with plenty of marbling.
You should be able to cut the meat with your fork.
Wow. No taste fatigue in Neal’s camp.
I have used a corned beef to make pastrami. I found that you need to soak overnight to remove a lot of the salt.
Smoke at 275-300° till 170° internal temp then then bring inside and steam for about 30 minutes till the internal temp is 200°.
Talk about delicious!
Here’s my Corned Beef/Pastrami recipes. I just cooked a Corned Beef yesterday.
Started it out on the smoker for an hour, then into the roasting pan with veggies until fork tender.
Pastrami and Corned Beef
Corned Beef
1 gallon of water
2 cups kosher salt
1/2 cup sugar
1 oz. pink salt (curing salt, not Himalayan pink salt)
2 cloves garlic
2 tbsp pickling spice
5 lb brisket
Combine all but brisket and bring to a boil. after it boils, chill it completely to refridgerator temperature. Put the brisket in and weigh it down to keep it completely submerged. leave in the fridge for 5 days.
Remove from fridge, and rinse.
Fill a cooking pot with enough water to cover the brisket
Strain brine, keeping all the spices and put these and brisket in pot. Boil until fork tender. I add cabbage about 15 minutes before serving.
NOTE: The original recipe had me cook the brisket in the brine and it was way too salty.
Pastrami uses a similar brine
1 gallon water
1.5 cups kosher salt
1 cup sugar
1.5 oz pink salt
1 tbsp pickling spice
1/2 cup brown sugar
1/4 cup honey
5 cloves garlic
Separate from brine
1 tbsp black peppercorns
1 tbsp coriander seeds
5 lb brisket
Boil brine and chill. Add brisket and weigh it down, just like the corned beef.
