CaptainGizmo
RVF Expert
- Nov 3, 2019
- Newell
- 2020P
- 2021 Grand Cherokee Trailhawk
Just wanted to open a thread to let you know that I’m working with Spartan on an issue with rye Cruise Control.
My config is a 2019 Dutch Star with an ISL (450hp) and Allison transmission. Though I’m sitting on a Spartan chassis, this problem affects the Freightliners as well.
When the Cruise Control is enabled/active, the Engine Brake will NOT go into High even if your speed overruns as much as 25MPH over the set point. The results in your speed running unchecked as you hit a downgrade more than 4%. Once you switch the CC off, the engine brake hits high and the speed starts to decrease.
I’ve identified that the Cruise Control is blocking the Allison trans from downshifting when the CC is active. This has been repeated and Video-recorded under numerous trials.
This is a real problem for us who are constantly going down grades from the Rockies and west; as much as 9%.
I’ve heard of all the “work around”, but frankly, and not accepting this as a normal and safe behavior of the CC parameters.
I’m supposedly going to be doing a field test with Cummins in the near future, in hopes to help with a solution. Whatever happens, I’ll come back and post an update.
