DEF Head
WinePress
After 56,000 trouble free miles I was greeted with an error code of DEF quality issue. SPN 3364. Was able to bypass with the simulator.
Question, can the head unit be serviced, cleaned, or is it best to replace? Any past experiences are helpful.
Thanks
Could be it just needs drained and replaced with fresh.
That would be the first thing I tried if it was just a quality error code.
Was it only SPN 3364 (DEF Qualify)? What was the FMI portion of the code?
a couple of things, when you go to the Diagnostic codes, the SPN and following numbers should be followed by FMI and numbers and the by OC which means how many times it occurred.
Depending on what Freightliner says that code means, there have been some success stories with people adding a can of Risoline DEF additive, a fairly new product.
Lastly, your codes will clear if the code was a one time code or quick glitch. It takes between 4-5 engine starts where the engine is allowed to run for 5 minutes or more. After that has happened, if the code was just a one time glitch or issue, it will clear.
