MapNerd
RVF 1K Club
- Nov 17, 2019
- Prince William, VA
- Ventana 4326
- 2020 Ford F-150
- Yes
That’s true in our 2018 Mountain Aires, but I don’t believe the Ventanas use the SilverLeaf control system. I think they are controlled at the switch level.The backlighting isn't controlled by a physical button per se. You press the button and it sends a command to the control panel. The control panel then responds with a command to turn the light off.
So the short answer is no, it cannot be done easily or at all. This is because depending on the age and year of the coach, backlighting works differently in different coaches. This is all determined by what the Newmar requests were for those years and those coaches. Backlighting is usually setup by regions throughout the coach with one of the switch in the region controlling backlighting in that region. This is all setup by the programming each part is initially set with and cannot be changed. Not all switchs can or do have backlighting buttons. Hope that helps and answers your questions.
Let me know if you want to try this on a 2016 DSDP 4369Most definitely. The system interfaces with both the KIB and RV-C (Silverleaf) networks. Obviously the capabilities are limited to monitoring and managing the devices that are on the network(s) its plugged in to.
For my coach, I control the shades, lights, water pump, exhaust fans, and KIB panel backlighting via the KIB interface. Basically those thing you can control from a KIB panel. It’s my belief that different year and model coaches probably have a different addressing scheme and possible devices, so additional work is required on my part to ensure that the coach specified stuff is user configurable. Given that I only have one coach, I’ve been limited in this area.
