TXheat
RVF VIP
- Jan 6, 2021
- Holiday Rambler
- Endeavor
- Roadmaster
- 350 Cummins
- None
- Yes
I'm not really sure how to phrase the question. On the Xantrex control panel there is a battery levels LED meter as most are familiar with and that will show that the battery is at around 11 or 12, The battery status indicator will usually show the the middle battery icon. Then after a while the level goes down and the status as well then if I press charge it charges up the battery, after it charges up I generally turn off the charge button, and it goes through the same thing again. I consulted the manual, from what a little understand it's not a good idea to keep pressing the charge button or overcharging?l I have not been able to understand how this works I should mention there is only one 12 volt deep cycle hooked up at the moment and that replaced 4x 6 volts that were in series. So what I don't seem to understand is if I'm connected to shore power why do I have to keep pressing the charge button unless something isn't working right?
