Dometic cfx75 w/ Bluetti Elite 100v2
fivestar828
Hi everyone! New to the forum.
I’ll be going camping in the summer (about 90 degrees and 60 at night) and plan to run the Dometic using a Bluetti Elite 100 V2. I’ll be using one compartment as a freezer and the other as a fridge, and I’ll also have a 200-watt solar panel. I’ll be using the DC input only.
Do you think this setup will be sufficient to run the unit for about three days? I understand it will depend on factors like weather and how often the fridge is opened, but I plan to keep it in the shade and open it only when necessary.
In your opinion, will this small power station be enough, or would I need a larger generator? Any input—or guidance on where I should post this question—would be greatly appreciated. I haven’t been able to find anyone with a similar setup that isn’t also charging from their vehicle. Thanks in advance!
Wish I could help but I dont know what a blueprint elite 100 v2 is. Hopefully someone else can jump in with experience. Interesting so ill be following.
